1 - 6 of 6 Posts
I have swapped the dash and harness out of a 96 PSD Into my 95. Everything works as should except for my wipers. When I turn my key to the "start" position not the spot where you leave it when its running but the spot that makes the engine turn over my wipers start working. I tried unplugging my multifunction switch and they still run when I do this. When the wipers are not running and I try to put a fuse in the spot for wipers it instantly pops. I really need to fix this any help would be appreciated!
Discussion Starter · #2 ·
also does anyone have acces to the 76 pin firewall connector pinout? I was under the assumption it was plug and play or am i mistaken?
Not a safe assumption, unless you know the cross-year swap has been done before. You really need the EVTMs of both years to perform a swap like that. I can scan the pinout from the '95 EVTM tonight. But you'll need the corresponding page from the '96 EVTM to compare.
Discussion Starter · #4 ·
I appreciate it if you could i guess i should have lol. Everything works as i should other than the wipers.If anybody has the pinout for a 1996 it would be much appreciated!
Discussion Starter · #6 ·
Thanks for the pinout i decided it wasnt worth doing all of the re-pinning so i put my old one back in.The reason i wanted to install it was the fact that it had factory rke. I just cut all of the rke wires out of the harness and im gona follow albertas write up on retrofitting rke on the org. Thanks for the help though!
1 - 6 of 6 Posts
