1 - 6 of 6 Posts
All, I have a 2008 F-250 4x4 FX4 w/ the 6.4 PSD. Any idea what the wiring harness out of my rear axle if used for? Thanks.
:ford:
Word
The sensor is used to measure the speed of the rear wheels, your carrier in your rear end has a ring mounted to it the spins along with the ring gear, this ring has teeth on it that get counted as they pass by this sensor...much like a crank sensor...it uses this info to calculate wheel speed and it's also used for the ABS system...
Also when it goes out your trans won't shift out of 1st.
1 - 6 of 6 Posts
