Hey guys, I'm new to this forum and am making my first post here. Too bad its with a problem.
A couple of weeks ago I started my truck up and it ran fine for about 10-15 minutes before it suddenly died. I checked the oil and it was pretty low so I immediately changed it. When I went to restart it, it again ran fine until it warmed up and would die. Some times it will die at idle and other times it will die if you try and touch the gas. It does not throw any codes and will not restart again until you let it cool down. It was working fine the last time I used it (it sat for about 2 weeks). I've never had this type of issue before and the truck has never shown signs of malfunctions. Here is what I've done so far:
Parts replaced:
Replaced the IPR
Replaced the CPS (Not OEM but didn't change symptoms)
Fuel filter
Fuel pump
Hutch/Harpoon Mod
Replaced the injector o rings on the drivers side (will do the passenger side this weekend)
AutoEnginuity tests ran:
KOEO:
- Test Completed Sucessfully
KOER:
- P1211 Injector Control Pressure Higher/Lower Than Desired
KOER Glow Plug:
- P1397 Variable Valve Timing Solenoid B Circuit Low Input
KOER Cylinder Contribution:
Readings while cold:
IPR Duty Cycle - 14%
IPR Voltage - 1.2
ICP - 800 psi
Readings while warm at idle (it let me run the numbers before it died):
IPR Duty Cycle - 11.72%
IPR Voltage - .9
ICP - 500 psi
Readings at 2k RPMs (not sure if the motor was warmed up or not but it eventually sputtered and died)
IPR Duty Cycle - 20%
ICP - 1200 psi
Other tests ran:
Injector harness ohmed out good
HPOP gear bolt is tight
Took out fuel filter and visually saw the fuel bowl fill at a good rate
What else could there be?
Bad HPOP
Leaky injector O-ring
Bad ICP
Parts replaced:
Replaced the IPR
Fuel filter
Fuel pump
Hutch/Harpoon Mod
KOEO:
KOER:
KOER Glow Plug:
IPR Voltage - 1.2
ICP - 800 psi
IPR Voltage - .9
ICP - 500 psi
ICP - 1200 psi
Other tests ran:
Bad HPOP
Bad ICP
