1 - 6 of 6 Posts
wasnt 99 a single disk and by 02 they upgraded to a triple disk? So itd actually be an upgrade.
Now that could be way out in left field, but thats what ive heard
Village Idiot
Yes ....you can even get a 6.0 or a 6.4 with minor mods.
Yes it will. Is your e99 converter making the marble sounds at idle? I just picked up early 99 with the famous marbles sounds
This was common problem with e99 and Ford said they would not replace on their dime. If your truck is stock then you could upgrade to a Daaco converter which is not too much money for a multi disk. Brian at BTS talked mi into a Daaco converter and Viton seal if trans is shiffting fine and I wanted to just run that stock trans to it's death. Might get years out of it
Yes it's been rattling for 15 yrs, I just thought to double check because I put in the 2002 torque, hopefully I'll get lucky and this torque will be good.
Thanks
Wes
1 - 6 of 6 Posts
