1 - 7 of 7 Posts
Just recently I go to pop the hood and nothing happens what will fix this?
I tried that didn't work.
FORD..THE ROCK CRUSHER
if it feels like the cable isnt broke...once in a great while ill need to have my girlfreind hold out on the hood latch while i hit the hood right above the latch..when it opens i spray it down with PB Blast...
Cable may not be broken! Have someon reach through the grill which will be the center driver side of the pickup and find the black cable that attaches the latch and have them pull all the slack out of the cable. Then go and pull the hood latch. At times what tends to happen is there is a lil set plastic piece that breaks and gives slack in the cable which wont allow you to open you hood. So for a shorter version...look for a small black cable through the grill that would attach to the hood latch, pull the slack out of it with one person and then pull the latch inside.
I drove it around and it popped. Srayed some WD-40 and now it seems to be working.
1 - 7 of 7 Posts
