1 - 2 of 2 Posts
I got the test kit, now what? Where do I obtain the samples? Thanks in advance.
Andy
Discussion Starter #2
Update:
I got some great advice from a member on another site. I bought the Rotunda #328-00008 Antifreeze Coolant ELC Contamination Kit and did the testing tonight. Everything worked out great and the coolant in both radiators tested fine. I highly recommend removing the grill assembly as it allows better access to the passenger side petcock. Due to the awkward, front facing, position of the petcock "release knob" I could not turn it past the first 90 degrees by hand. Otherwise not too bad. It would be nice to make a wrench short enough to be able to turn it while under the truck. Next time I will be more prepared.
1 - 2 of 2 Posts
