1 - 3 of 3 Posts
I have an 03 7.3 I converted to manual trans and single shot injectors and other stuff, jody flashed pcm to run w trans and injectors and put a tune on pcm but I'm wanting more options instead of just 1 tune it's mainly for towing but I want someone I can email or call to dial in the tunes.
Also since pcm already has a tune on it will it work w the hydra chip?thanks in advance .
Look up Jelibuilt, 1023, PHP (not so much on the call in anymore as they are wanting to stick with development), and I'm sure there are others... I know at least Jelibuilt has tune packages. I think you get 4 or 5 tunes. Custom work is a little more. The Hydra works by bypassing the PCM's memory so whatever tune you have on the PCM will stay there, but not be used (I.E. you can't have a tune on top of another tune). If you put the Hydra in the 00 tune position you could still use the PCM stored calibration (00 is the Hydra bypass).
Cj
Thanks CJ I actually had planned on jelibuilt after research but emailed them and waited then just called and left a message and no replies so I didn't know if they are still doing it or what also thanks for the info on the pcm
1 - 3 of 3 Posts
