1 - 5 of 5 Posts
Here's the run down.
'95 ZF5, 277K. Stock. Passes a blow by test very well.
- Bad glow plugs most likely.
- New Alliant relay.
- Leaks like crazy from the oil cooler.
- Leaks from the rear main.
- Fuel leak.. I have to pull the pump and bowl still.
- One of the injector harnesses has silicone on it from a "repair." I doubt it fixed the problem.
- White smoke obviously but I will elaborate.
Off a cold start it will idle and blow a good amount of white. Not super thick but a lot. As it gets warmer it will blow thin and just visible a few feet off the exhaust.
If I hold down the throttle it will usually stay at 2500 for a few seconds until the fuel clears up and then it will increase again. But when I do that holy crap it smokes. Like cover the driveway cannot see smoke.
If I'm driving like a normal person with normal shifts and a good operating temperature.. no smoke. On the highway.. no smoke. Good temp and get on it.. smokes like crazy.
This is not a daily.. it is a project and I have time and some money to put into it. I have lots of parts at home waiting such as rear main seal, oil cooler seal, oil and filter, MBPR downpipe, a new valve cover with the harness', and an intake. Here are my ideas regarding the smoke..
- A couple dead injectors
- The bad glow plugs
- That burnt harness
- Running it low on oil in general
- Worst case scenario, low compression
I want to put Stage 1 or 2's in the truck eventually, but I'd like to put those in along with efuel, intercooler, and a clutch all at the same time, so I just want to get it running healthy while I save. Any advice is appreciated.
How cold is it where you are? Have you tried / tested the block heater? Would be worth knowing about now, so if it turns out the element is bad you can swap it when you do the oil cooler work.
Glow plugs are prime suspect #1. Esp. the burned up connectors. Fix/replace the connectors, test/replace the GPs, GPR, etc., see where that leave you smoke-wise.
1 - 5 of 5 Posts
