1 - 4 of 4 Posts
if the truck sets overnite and i crank it in the mourning and try to drive it it pours white smoke. after it warms up its fine. Just put a 5' turbo back straight pipe w/ 4' down pipe and bullydog on it. might have been doing it before i can just see it better now!
Attention Whore
Does the smoke smell like diesel or coolant?
If it's diesel...start checking injectors.
If it's coolant your egr cooler is leaking.
I had that problem with a '06 F350 and it was the FICM going bad, tested out at only 42v, Ford replaced under warranty and all was good.
Word
You said you have a BullyDog Programmer on it....if it's set to any performance setting it's changing the duty cycle of your injectors, it's putting more fuel in all the time, which would explain a little smoke at idle or when first driving until it warms up....remember also you now have no DPF, CAT or Muffler to cut down on the smoke...and you added a programmer, this is typical...nothing to worry about...
1 - 4 of 4 Posts
