1 - 16 of 16 Posts
cjsobas
i have a 2000 f350 the dash is the dull green factory lights and black cluster. i would really like to change this. i wanted white around the gauges so i ordered a overlay from whitegauges.com. they just stick on the factory overlay. now as for the color i am having issues finding out how to remove the green tint from the back of the gauge overlay. how would i go about removing the needles and putting them back on so they are acurate.
i ahve this idea that if a take a 9v batt and some jumper leads and conect it to the gauge terminals then mark where they sit it will be acurate. or i might fry the board :badidea:
also i was wondering if there was a tool i needed to remove the gauge needles.......
cjsobas
thanks it did kindaa lol. when you removed the needles how did you make sure they were accurate and or back in the same place
Road Hammer
To be honest, I haven't gotten to it yet.
What I'm going to do is just take a picture of the needles when the engine is at warm idle. Then just try to put them back in the same place. The Speedo, Tach and fuel level are the only ones to really worry about accuracy, the rest are just basically idiot lights/dumby gauges.
cjsobas
Well I'll be doing all this all at the end of the week. Guess I'll find out if I break anything. And how hard it will be I will definitely post pictures and a detailed explanation of how hard it is. Because its a neat interior mod if i can do it
Village Idiot
There are some picks or a video floating around, were They show how to scrape the green coating off. Was pretty straight forward.
FORD..THE ROCK CRUSHER
if your putting in a new face there should not be any green to scrape off..just swap the bulbs..mine glow blue but i dont have a night shot..i did mine very first thing in the am when motor was cold and all gauges where reading 0..then you dont get confused where they where...if i remember right (i did this mod 6 years ago and my truck is parked for the winter) doesnt all gauges read 0 with the key off any way's??
cjsobas
Discussion Starter #9
the face just sticks on the original plate. that's why the green needs to come off they wil look good hopefully lol. and yeah with the truck off and cold the gauges should stay the same. but i heard if there not on then they roll back and out of place. idk if it true or not
oh ya..that's a little different then what I have..mine I toss the old face and put in the new one piece face...
cjsobas
Yeah. I looked around for one that looked factory just white around the gauges not the whole face. But I couldn't. Then I found this for only 15 bucks
cjsobas
And are all the gauges reading
accurate when you removed the needles did it with the key off
The Oracle
the 9v battery, or engine dead cold with key on, are the best ways to do them.
if you remove them are rest(no power) the pin/motor can spin and they will not be correct when reinstalled
**and i use a regular kitchen fork to remove the needles**
bottom one is DP tuner F5 the top is a SP diesel TC lock up switch..it locks and unlock the TC at what ever speed i want.. .i dont use ether one of them any more
1 - 16 of 16 Posts
