1 - 3 of 3 Posts
SD NEWB
Hey All I called my ford dealer today to order a shim to help with my lean problem and they told it would 261 dollars:eek: I asked if they were sure that was correct and they said it was for the part number they gave me. I tried to get em to look it up by TSB but the lady said she couldnt. Anyway anyone know where I can pick one up?
Village Idiot
One ford dealer on here had good oem prices..maybey look for sunrise ford in vendors section. Or google tsb for your truck see if the actual tsb has a part number.
99-05 F-SuperDuty Rear Suspension Lean:
This applies to rear suspension lean only. The truck needs to be parked on a level surface with no load (or at least loaded evenly) and all tires inflated evenly. Inspect for spring damage or shackle bushing wear. Measure vertically from the lowest point of the wheel rim (not from the ground) to the wheel lip. If the measurment is within 3/5" from side to side, no action is required. If the measurement is greater than 3/4", measure the gap from the top of the axle to the rebound bumper bracket. If this measurment is within 3/4", inspect the body mounts and have the frame checked. If the measurement is between 3/4-1", install shim 3C3Z-5A300-AA on the low side, between the spring spacer and spring seat. If the measurement is between 1-1.75", install shim 5C3Z-5742-AA on the low side. If the measurement is greater than 2", replace the spring. Install longer U-bolts if necessary.
TSB 04-23-6
Got this off of:
http://www.intellidog.com/dieselmann/bulletin1.htm
1 - 3 of 3 Posts
