1 - 3 of 3 Posts
I have a 95 7.3 f250 that wont start. I'm looking for a set of test gauges for fuel and low oil pressure test and have found it VERY hard to locate a vendor. Any suggestions that wont break the bank?
Why don't you get good scanner that can monitor live data ? a hell of alot easier than trying to buy / make mechanical guages that would read what you want to know...
Are you getting smoke ? does your tach move when you crank it ? are your batteries in good shape ? is your IPR connection good ? what is your fuel pressure when cranking ( you can use a tire guage)...
It's been awhile, but I purchased liquid filled gauges for the FPR (0-100 psi and shraeder valve fitting/hose) and the HPOP (0-5000 psi I think with adapters) from Dale Isley at TYMAR. Cheers!
1 - 3 of 3 Posts
