1 - 5 of 5 Posts
<<< Power
Seen this on CompD, so I added the ferd transmissions, and here you go.
There are two standard ratio sets for the ZF5's. Apparently one was a gasser model, but ended up in some OBS PSD's.
I put the "close ratio" (diesel) set in the chart, so here's the "wide" ratio's, in case anyone has one of those.
Wide Ratio
1st Gear: 5.72
2nd Gear: 2.94
3rd Gear: 1.61
4th Gear: 1.00
5th Gear: 0.76
Rev Gear: 5.24
2nd chart has 5R's.
Mods, if I missed this somewhere, this thread can go away. If not, might make a good sticky.
OverFuelingForYourPlesure
That is a very handy little program! however the gear ratios are differant between the obs and superduty transfer cases and it looks like you have them all at 2.72
Crazy Talk
what is the sd tranfer ratio? and for the case behind the zf5? what about the 4406? its 2.72 isnt it?
<<< Power
Best I could do guys. I didn't write the formula that is making the conversion in those charts, but FWIW, it's about dead on for the 4R100 in my 3.73 truck.
That said, I thought SD's and OBS both had 2.73 transfercases, or something close to that...
Guess I better crawl under the truck and see if the tag is still there.
1 - 5 of 5 Posts
