1 - 6 of 6 Posts
I'm looking to move onto another project. I've owned the truck since January 2010. I swapped in the 94 12v back in August 2011, finished it in the beginning of December 2011 and have been driving it daily ever since. I have about 30k on truck since swap. Truck came from Texas so has only seen three winters up here and washed on a weekly basis so the salt isn't on long. Here's the spec on my truck:
2004 F250 lariat ext cab FX4
about 137k on entire truck
Cobalt c2 gauges (boost, EGT, trans, and Volts)
Recon Cab Lights
Aftermarket harley headlights
HID 8000k headlights and fogs
Front end rebuilt about 20k ago.
16x10 (I think) mikey thompson wheels
new 285/75-16 tires put on during the swap, still have at least 50% tread life
Line-x bed
Under coated the truck last fall
Roll up ACCESS Lorado.
5% tint all the way around
Engine:
94 12v
When I picked up the engine, Pulled the head off and dropped the oil pain, replaced all the gaskets and seals.
ARP studs
New 90hp injectors from Contagious diesel
HX35 turbo
4k gov spring kit
Hardened exhaust valve springs
AFC and smoke screw tweaking
Timed to 18*
New waterpump, alternator, AC compressor
New PS pump and starter in the last few weeks.
Trans
Zf6 out of an 01 superduty with same miles.
Southbend single disc rated for 600-650 hp.
I love the truck but the lady doesn't anymore. By no means do I have to sell so if the price is right, then maybe I can let it go lol.
Ill be giving the truck to my buddy to finish the AC lines and get the parking sensors hooked up.
I'm thinking its worth at least 20k but maybe I'm biased so I'm looking for outside opinions.
I'm sure I'm forgetting a ton of stuff so ask away!
Sent from AutoGuide.com App
Id guess youd top out around 20k. Reasoning being that its only worth more if someone wants or likes the exact same things as you. Ie, someone else might prefer autos, may prefer crew cab, bigger/smaller tires etc.
I always figure these are worth essentially what the title says it is, regardless of mods. Those mods only add a little. Hopefully you get more for it, I honestly hope you do, but you'll have to advertise it for a while Id bet. So sell it quick for cheaper or sit on it, to get what its worth.
I would say 13 to 15k. If you didn't go with a 94 12v and had went 2004 or newer cummins I'd say 20 would be about right. That's my guess. I mean its basically a stock 94 with headstuds and a couple hundred dollar injectors. Through a benched 918 pump on it with a set of 5x14 sticks and a quality e.d. Turbo and you'd have a damn good running setup though and you may want to keep it.
I wish I would of gone with a CR but I got such a good deal on the 12v, I couldn't pass it up. Lee over at contagious steered me away from 5x.14s bc of my turbo size currently...
Yeah they would run hot on that stock turbo. But for around 1800 or so you cold do a sweet 62/71/14 or even a 64
I you had a common rail I'd say 18K-20k. With the 12v I'd guess 12k-13k. If you find a 12v lover and there are lots out there you could get more. I'd start at 18 and see where it goes.
Everything will have to work, gauges, cluster, a/c, parking sensors. People usually don't want to buy something to work on or get the impression anything is hacked. JMO.
1 - 6 of 6 Posts
