1 - 20 of 40 Posts
A powerstroke 4x4 one with 200k... Its off a truck im parting out, I was thinking $500?
With swap parts think its worth $600?
STILL LEARNING
I get 700 for just the trans, What year is yours?
Bushwacker
how much power could the s5-47's handle because i rebuilt mine and im not as happy with it but i think this luk clutch i put in is a POS and itd be happier if i upgrade to a south bend
STILL LEARNING
How much HP you putting thru it?
Bushwacker
I'd like to see it handle roughly about 500 wheel hp eventually. I do know that s5-47 stands for synchronized five forward speeds and rated to 47 ft.lbs. of tourque times ten which is 470 and the older s5-42's are obviously 420 but I seriously believe the gearboxes are seriously under rated because obs ps have 500 ft.lbs. stock. Oh and I'm probably making 300 to the wheels if that as of now
STILL LEARNING
I think you got your numbers mixed up the OBS were only about 450ft/lb/tq
< Can I drive?!
I bought my high mileage ZF5 and tcase with other hardware to swap for 900
Bushwacker
Interesting I could be wrong either way it's making more than 500 ft.lbs. now and it's holding up I just feel this luk clutch is my issue
STILL LEARNING
In 3 trucks I put tuners in, I smoked the clutches in less than 3 days each. The last one had less than 1 year and about 8k on the NEW clutch.
I must have some strong running trucks to smoke 3 clutches
I thought you could sell the whole swap kit for around a thousand bucks... That's what my buddy paid for his.
1 - 20 of 40 Posts
