So last night I was driving home and decided I would take the truck up over 4000rpm to double check that it does fuel at that rpm. Didn't quite make it though. When I hit about 3800 the truck made a noise like hitting the rev limiter, ran real rough for a couple of seconds and killed. Wouldn't re-crank. I also got a scare 'cause at the same time I heard something metallic knocking around. That turned out to be the exhaust coming loose from the down-pipe fortunately.
Tried cranking it again this morning and it wouldn't. All fluids are fine, no metal pieces any where.
Put the AutoEnginuity on it and got the cps code. Had a spare cps so I put it in; truck cranked up. Did take a tiny bit longer than normal, but cranked and idled just fine. Drove it around the parking lot and all was good. Pulled it into the shop. Fixed the exhaust. Cranked it back up.
Popped the hood to check the trans fluid and the truck started "skipping". Then it would come back to normal and idle fine. It did it a couple of more times and then killed. Cranked it back up ran for about a minute and started skipping again and killed. Every time I craked it up, as stated earlier, it took a tiny bit longer than normal to crank.
I'm gonna call David tomorrow, don't really feel like bothering him with it on his day off. I'm sure there's the off chance that the cps I replaced it with was bad too, but in the event it isn't, what else could it be and what else should I check?
