My truck has been running well, but it still has a few little hiccups that I haven't diagnosed yet. Occasionally, when cold starting, it surges about once per second between ~700~1200 RPM until I raise it above idle & hold it for a few seconds. Then it idles low for a few seconds & runs fine. That happened before & after I adjusted the IVS tab for less dead pedal - maybe too little because sometimes it wouldn't respond until I dumped the pedal back to idle, but that seems to have stopped happening. For about a week last month, cruise wouldn't set, but now cruise works perfectly. Last week, I loaned it to a friend, and he said it was a dog getting going, and up the slightest hill. I though the boost gauge line had blown off the MAP again, but after I got it back, it turned out to be the trans starting in 3rd (or maybe 4th). All I had to do was pull the shifter down into 1st, and manually shift up to D. But it would still NOT kick down until it had really warmed up. Then it would go back to normal automatic shifting. I still haven't changed the fluid since buying the truck, and I assume it's factory (because so much else was), but it's not low or dark; just sort of dilute-looking. ForScan app & FoSeal adapter show no faults.
I don't know enough yet about electronic diesels or automatic transmissions to even have a guess if these are related, or why they could come & go. Are there any tests & can do to identify or exclude any possible causes?
