1 - 5 of 5 Posts
I am looking for suggestions on what happened here. Had a new set of d-Tec injectors put in. About a month later the truck started to run away pulling a load. It finally just #### itself down. Got it towed back to shop and found the crankcase was full of diesel. Pic of first cylinder on driver side.
"resident smarty pants"
I think DIPACO DTech needs to answer that!
Can you verify that the torquing procedure was correct/accurate on the hold-downs and that new copper washers were used?
Administrator
this review sounds familiar
worst injectors you could ever buy we installed a set and within 2 miles melted the piston when it come tome to fix it they stiffed us and we paid for engine rebuild and replaced their injectors with bosch 505rx and truck has worked perfectly for the last 5 years YOU HAVE BEEN WARNED
1 - 5 of 5 Posts
