1 - 5 of 5 Posts
Just replaced my bad factory alternator with a DC High Output alternator. I'm curious what the voltage should be at the alternator? I checked the voltage with a meter and at the alternator post and I'm reading 14.6 volts. When I look up battery voltage on my Edge CTS is reading 13.9 volts. So am I ok, is the voltage to high, to low or am I in the ballpark? Thanks!
I am pretty sure that is good.
Yep. The OBD port will read about .4volts lower than at the alternator
2005 F350 CCLB FX4
altenator should put out 14.4 volts that is what the rectifier is desinged to put out
1 - 5 of 5 Posts
