1 - 12 of 12 Posts
Hello all,
I'm tired of fixing my 6.0 and am in the market for a 7.3. Found an 02 that I am going to look at, what are some things I should specifically be looking for? I have an AE, have never plugged into a 7.3 with it before though, what should I be looking for other than codes and injector buzz?
Thanks
I'd check the IPR duty cycle at idle and monitor the ICP on a full throttle run to see what kind of shape the hpop/hpo o rings are in.
I believe there is a MAP sensor output on there too, I have a boost gauge so I've never looked at it on AE. Check to see how much boost its making on the full throttle run. This will give you an indication of intake boot condition/leaks as well as how the up pipes are doing.
Well its not a 7.3 but it is what's behind. It is pretty important and can be expensive to repair...an automatic transmission...if it has one. I'd want that to be in good working order or that 7.3 isn't going to do too much.
Caption This
What ICP should I expect WOT with a 7.3? And what duty cycle range is considered normal?
The truck I'm going to look at has 120k miles, looks to be in really nice shape but.......it has an Edge programmer on it :doh:. Truck is an auto....
I drove the truck while the AE was plugged in. Max injection pressure we saw was 2280 psi @ 39% IPR? Not sure why it didn't command higher pressure?
Check the air filter to see if dirt got past.
The truck apparently has a drop in K&N filter, so I wouldn't be surprised if some did. Can you elaborate on how you think that would cause a lower commanded pressure? (if that's in fact what your getting at?):ford:
I would pop the oil fill cap off while its running to get an idea of wether or not it has any blowby.
I second the low miles no mods. Also oil pan rust/rot. I also agree with checking for blowby, after its at running temp. Making sure the trans shifts proper too. The cam position sensor is also something to ask about.
7.3 Yep I got one too
I would pull the turbos air ine going to thefilter and check the turbo for shaft play. Look up my post on turbo shaft play. I thought II could rebuild but have to replace. I would also spray water over the engine and see if it runs bad. If so there is a short somewhere. All things I have had to deal with on mine. I also had to rebuild a tranny last year. Good Luck
FORD..THE ROCK CRUSHER
1. Visual: Body and rust are obvious items, nonspecific.
A. Engine
1) Check for any obvious fluid leaks, especially the engine valley, tranny weep hole area, and around the turbo and pedestal.
2) Check coolant with strips and find out the record of any changes or water pump replacement based on mileage.
3) If possible, do compression check, and Cylinder contribution test.
4) Inspect turbo inlet side vanes, should be straight and not dusted or jagged. Try to move the shaft in and out and up and down. Any real noticeable movement by hand is bad. Open and inspect air cleaner assembly for an idea of how it was maintained.
5) If possible, have fuel pressure tested at engine to check pump.
6) Check all intake /intercooler boots for residue or leaks and correct before trying to determine engine condition.
7) Look at oil pan for notorious rusting, make sure not beyond repaint type repair.
8) Know whether you're getting forged or PMRs. 99-mid 01 = forged, anything later is possible or for sure PMR. Not an issue until you exceed 400HP.
B. Transmission, driveline and 4x4 system.
1) Look for any obvious leaks.
2) With the system in 2wd, grasp and rotate both front drive axles and ensure they rotate freely. Go to the hubs, ESOF and manual should rotate from lock/auto to free with no problems.
3) Grab rear driveshaft and push up and down along it's length checking for worn u-joints or bearings.
4) Check front and rear differential levels. (An indicator of maintenance) Level should be at or w/in 1/2 inch of check plug.
2. Test drive. If you have never owned a 7.3 PSD, try to get a 7.3 owner to test drive it. I did this with a friend who bought his new. Invaluable evalation because you have no idea. A stock PSD may feel like a slug to the gasser uninitiated but it can pull a house off of it's foundation. So here we go.
A. Drive more than one PSD truck that you are considering. Whether Auto or Stick, it will give you an idea of the overall condition of the one you want to buy. Cost = 0. Learning curve = super high. Dealers have a ready supply.
B. Startup. Turn key and watch wait to start light. The colder it is the longer it will take but should take no longer than 15-20 seconds on even cold days. Start engine. Should crank readily and turn the tach while cranking (although mine does not). Should start within 2-5 seconds of cranking. The colder it is the longer it will take but if longer than 5 seconds there may be a problem. Even in colder weather. If it does not not start easily on the second try, suspect problems, possibly in the glow plugs or GP relays. If it does not crank readily, or seems to drag, suspect batteries first, starter next, then cables.
C. Driving. Check all operational items. Don't be rushed. This is a major investment and you want to get it right. Even small items like the cruise will set you back.
1) Auto tranny: will feel like it takes the throttle to get moving with a stocker. The higher the mileage, the worse this will be. The shift should be smooth but slippy with a stocker. Long to engage. Convertor lockup will be almost imperceptable, but there. Will lock up at about 45 to 60m depending on throttle in OD. Should drop out of OD with input to brake or reduction of speed.
2) Standard: give input
3) Ride: if it is bouncing down the road, you can look to having some problems to take care of. These can be tire balance. Tires, or some unexplained seemingly incurable symptom that you may have to live with which is unacceptable and not common, but does happen. Some say it is an out of balance driveline but there is no universal cure.
4) Exhaust drone. Only happens with aftermarket exhaust due to what I believe is harmonics resonating in the thinner walled aftermarket systems. Not a big solution at present but not a performance issue.
5) Performance. There is no hesitation in the PSD 7.3 when all is in working order. Any hesitation is an indicator of a problem. By design, if all is in order, at throttle tip in, it simply responds. No excuse such as mileage considerations. This = repair bill.
1 - 12 of 12 Posts
