V1 DIAGNOSTIC TROUBLE CODE (DTC) P1663
DTC P1663 indicated that the PCM has detected a failure on the CID line. Possible causes:
-- Open/short in CID circuit
-- IDM
-- PCM
Check for other codes. Key on, engine off. Perform KOEO On-Demand Self-Test and retrieve Continuous DTCs. Was only DTC P1667 present?
Yes: If DTC P1667 was present, Go to «V2».
No: If DTCs P1663 and P1667 are set together, with or without DTC P1668, GO to «U6».
If DTC P1298 is also present, REPLACE the IDM.
If DTC P1662 is also present, GO to «W1».
V2 CHECK VOLTAGE ON CID CIRCUIT 817 (Y/LB)
Install breakout box, connect PCM to breakout box. Key on, engine off.
Measure voltage on Circuit 817 (Y/LB) between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103. Is voltage of 0.6 ± 0.1 volt present?
Yes: GO to «V3».
No: Voltage of less than 0.5 present, GO to «V4».
Above 4.0 volts is present, Go to «V5».
V3 PERFORM AN OUTPUT STATE CHECK
Key on, engine off. Perform KOEO Output State Self Test, toggle outputs by pressing and releasing the accelerator pedal. Measure voltage between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103. Did the output voltage toggle from 0.6 ± 0.1 volt to B+ volts?
Yes: Intermittent, GO to «V8».
No: REPLACE the PCM. RESTORE vehicle. CLEAR DTCs and RETEST.
V4 CHECK FOR OPEN ON CID CIRCUIT 817 (Y/LB)
Key off. Disconnect the PCM from breakout box. Disconnect the IDM connector. Measure resistance on Circuit 817 (Y/LB) between PCM Test Pin 96 and Pin 16 on the IDM harness connector. Is resistance less than 5 ohms?
Yes: GO to «V6».
No: REPAIR open in Circuit 817 (Y/LB). RESTORE vehicle. CLEAR DTCs and RETEST.
V5 CHECK CID CIRCUIT 817 (Y/LB) FOR SHORT TO POWER
PCM disconnected. Key on, engine off. Measure voltage on Circuit 817 (Y/LB) between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103. Is voltage present?
Yes: REPAIR short to power on Circuit 817 (Y/LB). RESTORE vehicle. CLEAR DTCs and RETEST.
No: GO to «V7».
V6 CHECK CID CIRCUIT 817 (Y/LB) FOR SHORT TO GROUND
Key off. Measure resistance between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103. Is resistance greater than 10,000 ohms?
Yes: GO to «V7».
No: REPAIR ground short on Circuit 817 (Y/LB). RESTORE vehicle. CLEAR DTCs and RETEST.
V7 CHECK PCM OUTPUT STATE FUNCTION
Key off. Connect PCM to breakout box. Perform KOEO Output State Test. Measure voltage between PCM Test Pin 96 and ground Pins 25, 51, 76, 77, 91 and 103 while pressing and releasing accelerator pedal. Did the output voltage toggle from 0.5 ± 0.1 volt to 0.0 volt?
Yes: REPLACE IDM. RESTORE vehicle. CLEAR DTCs and RETEST.
No: REPLACE PCM. RESTORE vehicle. CLEAR DTCs and RETEST.
V8 INTERMITTENT
Key off. Restore vehicle. Clear DTCs. Turn key off, then turn key on. Perform KOEO On-Demand Self Test. Did DTC P1663 reset?
Yes: REPLACE the PCM. RESTORE vehicle. CLEAR DTCs and RETEST.
No: Unable to duplicate failure. RESTORE vehicle. CLEAR DTCs and RETEST.
