1 - 4 of 4 Posts
What will I need to mount the 467.7 turbo with .90 v-band outlet. What kind of performance will this turbo bring and how bad will the lag be. Pickup has adrenaline hpop, stage two injectors, going to put a fas fuel system on it.
For mounts: either Carson Stauffer Diesel or Irate Diesel.
I would say skip the FASS because most people say it isn't good for the 7.3. FASS is lower pressure, high volume, while the 7.3 needs high pressure, high volume. Check out Irate for this too (what I have)
Need to be specific on injectors, "stage 2" doesn't really mean anything. Need XXXcc/XX(X)%. I will assume by stage 2 though that you don't mean hybrids, so I am thinking that turbo will be way too much for your injectors, but could be wrong. Most people run that turbo with 250/200s or 300/200s which are definitely not "stage 2s"
The injectors are 160cc 80% but after these go out I’m going to put bigger injectors into it.
1 - 4 of 4 Posts
