1 - 3 of 3 Posts
I'm thinking about redoing my suspension for a little softer ride. Currently i have an 8" Icon all spring lift. I'm thinking of doing 4.5" hanger/shackle kit and 4" Icon springs in front and OUO traction blocks with factory springs in rear. What size block would i need to match the front? Thanks
That is the lift I currently have on my 01 but I have blocks in the front. I am looking to upgrade to an 8", what are you looking to do with your 8"?
Lost Cause
I have the Icon 4" springs with 3" hanger/shackle in the front. In back I have Icon 5" springs and 1" block and it sits almost level with about 1/2" slope over the length of the 8' bed rails.
Since you're effectively going 1.5" higher than my setup, figure 2.5 - 3" block and the bolt on bar mounts (what I run) if you use the 5" Icons or a stock pack with a 7" or 8" taction block.
1 - 3 of 3 Posts
