1 - 20 of 50 Posts
WWDD
I know that the real fix for front end hop on coil springs is 4 link but i just need to get some shocks for right now which ones?
I was going to get some summit racing drag shocks, only problem is i can only get them in 70/30 dampning, not sure if that will be enough to keep the front end from bouncing, let me know what you guys think
Re: what shock you coil spring guys running
I'm not sure if they will help or hurt, but I have some procomp 9000's sitting in my garage. If you have a chance to test them at all let me know and they are yours Dustin.
WWDD
Discussion Starter · #4 ·
i ordered some rancho 9000s or whatever they are, a buddy of mine thought that he had a set of the 9000s already so i think im lined out for shocks, thanks though
RCD sells Bilsteins adn uses them in all their kits...FYI, we are a RCD dealer..
WWDD
Discussion Starter · #7 ·
Im bringing this one back from the dead, rs9000s didnt work on my truck, still hopped like crazy. Im going to try a set of summit shocks but the information is a bit confusing...
here is what is posted on competition engineerings website about there shocks.
Competition Engineering's Front Drag Shocks are adjustable in three ratios: 90/10, 80/20 and 60/40. These ratios reflect the percentage of force required to extend and compress the shock absorber.
This seams backwards to what we need, we need hard to compress, easy to extend.
I think you would need them the other way for pulling. Those are drag shocks
90/10 in the front and 60/40 rear for a 2wheel drive to transfer the weight to back. The front would lift and hold and the rear would drop and hold.
you want a 10/90 dont know if they make that.
amos moses
Keep us updated! My first pull is gonna be Saturday an I'm sure it's
gonna be a bouncy run!
amos moses
i have also been considering that aswell. maybe ill give that a shot.
amos moses
Went ok no hop at all! But trans kept shifting 2nd to od I believe. Waiting on an e-mail for the video! I'll make a thread when I get it!
amos moses
Pulled 4low 2nd was gonna shift to 3rd but truck shifted on it's own I believe strait to overdrive then back down to 2nd! I ran 23psi front and 43psi rear!
amos moses
Nope just got the sled rolling and hammered down! The track sucked And the sled was tough! Full pull was 165ft lol. Winner pulled 135 I pulled 94ft
1 - 20 of 50 Posts
