1 - 15 of 15 Posts
Ok well i think i have kinda plataued with the truck. Currently with all the mods in my signature what do i do now. I have considered Water/Meth, paticullary for the egts ad also helping with cleaning the cylinders from running WVO. Then again have cosidered Nitrous but that is hit it and quit it thing. Where as water meth can be kinda constant.
I used the truck as a daily driver. I tow a 7k Mud truck and trailer a few times a year. Go cross country with it every 5 years, other wise just an awesome DD. I dont know what to do next. Plans of dumping the stacks and going with a MBRP turn down exhasut. just trying to see what everyone thinks. Pics on request. Thanks
I Love Work'N On Hot Rods
TWIN TURBOS!!!!! and a NADP tranny.
WOOOOO!!!!!
Twins with those sticks would be fun!
get rid of the pmax and do twins or just a non vgt turbo! im sure you would be happy with that and i bet egts would be lower
With Twins and a tranny you could tow with probably 550hp or more. JMO.
Well let's see what else comes in twins I want: turbos, boobs, and 21 year old college girls. Some are more likely than others and I can't afford a single one on the list. I think first on my list should be a NADP trans. #### twin turbos and a trans cost about the same. Maybe one of those can happen when I re-enlist. I also think changing gears I will get a little umph back. Idk just trying to think of what to do.
get a batmowheel then
Damnkids Motorsports
That powermax is killing your performance with those huge sticks. It's really the limiting factor here. A 64 non VGT with a diverter valve to spool it quick might be ok... If you really want to keep towing and often, compounds are the only way.
Discussion Starter #9
64 non vgt batmowheel with a diverter valve is what i want definitly cheaper than twins and would really open new oppertuities with the diverter valve. may even be able to run a 66mm with the diverter valve.
thats what i said earlier but though you didnt wanna spend that much thats why i said batmowheel but yes that would be a good upgrade! you could sell your powermax pretty quickly also!
My whole reason for getting the Pmax was that it was better than stock and i would rather run with a Pmax than stock if i dont have the money for the right turbo. Since getting the money for a 66mm batmo, diverter is much more than a pmax. so i will wait for that. Besides Turbo and Trans what other mods have you done that you may recommend?
how about an intercooler or dougs ported intake manifold?
I've got a W/M set up and NEVER worry about EGT's anymore. Even pulling 12K. Plus, I see about 1.5 mpg increase on avg. I run a 70/30 w to m mix. Saving some $$$ for a stage 1 manifold.
You can add a few smaller things, but like they said the turbo is really what needs upgrading now.
W/M is probably your next best step kenny.
Discussion Starter #15
I agree on the turbo. Well for now i think W/M is on the top of the list. More benefits that other mods. So does anyone recall a good thread on W/M kits. I was thinking about SNOW MPG kit but is that really needed? Should i build my own or what the best thing to get? Can start a new thread if needed?
1 - 15 of 15 Posts
