1 - 9 of 9 Posts
WAT WAT IS A ZOODAD MOD I HAVE NO CLUE AND WONDER WAT THE CRAP IT IS
Discussion Starter #2
srry for caps
Its taking a hole saw to the plastic piece in front of the air box and making a direct path for air to the filter. Named after "Zoodad" at TDS
The Stig
most cut the whole the same shape as the intake, takes about a 2-2.5 inch hole saw, cut two holes vertical to each other, and take a dremel or pipe saw and cut it till it makes the correct shape and smooth the edges with the dremel or hand file.
ok thank you lol it was driving me nutz does this mod add any mpg even a lil
ok thx
The Stig
it just makes sense to do it, lets air straight into the intake, no reason not to really, although you don't really see any gain by it, maybe a little bit more sound when you shut the thing down.
Thats what everyone calls it, man did that to every ford i have had since 04, LOL cool name. Makes a big difference if you run Propane, better airflow like ram air just a whole lot cheaper.
1 - 9 of 9 Posts
