Truck is in no start condition. When I test the fuses with a test light fuse 22 does not light up. The fuel bowl wire harness looks okay. The wires do not seem to be shorted out and all the insulation is on them. Where else do I need to look?
After a Buzz test with Car Gauge Pro I got a bunch of codes. Hopefully one you can help me out on this one. Also, I used a test light to check the fuse box under the hood and fuse 22 didn't light up. I have continuity when using a multimeter and I pulled the fuse, it is good.
Here are the codes:
P0270
P1277
P1275
P1291
P0012
P007C
P0001
P0603
P1212
Any help would be very appreciated!!! I really need this truck back up and running A.S.A.P!!!
Here are the codes:
P0270
P1277
P1275
P1291
P0012
P007C
P0001
P0603
P1212
