1 - 16 of 16 Posts
hey guys i went out today and put my truck in 4l 3rd gear with erics x-street and x-race and i was just messing around to see. But when i would hammer on it and get the rmps to say 3200-3500 it would just snap and take off, was that my turbo just lightin or what. Just tring to figure out what that is and what gear to pull in. Truck has 03 turbo and eric tunes, Will have trac bars whenl pulling they are sitting in the barn. Just needed put on
If in doubt, tach it out
I run 3rd on the low side. That "snap" of the throttle is common. You probably wont notice it once a sled is behind you.
The only problem with 4hi 1st gear is you can't lock the converter. I like to boost launch in 2nd low and manually shift to 3rd low with a locked converter, I have a unlock switch for tight tracks.
In 3rd low you can get more HP to the ground and loose less threw converter slip.
Discussion Starter · #6 ·
i pulled last year with my truck in 4l 3rd but i didnt have my sct than i used my buddys ppe. Im sure its a different ballgame with the torgue converter locked. I did win my classs somehow with that ppe
Well this is something i have been wanting to know cause i would like to try to hook to a sled wit mine and see how it does. I have an sct with custom tunes from tony wildman, working on traction bars for the rear
so if am understanding this right you guys suggest 4 wheel low and in 3rd gear, no shiffting or nothing just lock it in 3rd gear and mash the go peddel is that what i am understanding
I start in 2nd and shift to 3rd. I burnt a converter by power braking on the line in 3rd, won a lot of pulls but it was hard on the converter.
I have a manual and pull 3rd 4low
Death Row Inmate #7
i would think that the 5 speed manual trans guys would be good pulling 3rd in 4Lo. With that said i would imagine the 6 speed trucks should be able to pull 4th gear in 4Lo
With my 97 I would pull 2nd low. My brother and my brother-in-law both have 06 6.0's and pull in 2nd low (they both have SCT's with Eric's tunes) with great results. All manual trucks.
http://www.youtube.com/watch?v=3-CEfAXwoBQ
Nice!
I'm on the other side of the mountain in Shippensburg!
Howdy neighbor!
I don't think you will get 4th gear low range with the manual unless you put lower gears in it, I pull with a 2.6 6.0 6 speed, I pull 4 low in "marked" 3rd gear witch is actually your 4th forward gear. But back to the guy that started the thread: built transmission? what size and type tires? what type of track? what modifications to the truck?
1 - 16 of 16 Posts
