What gauge is the crossover cable?
515 Views 8 Replies 6 Participants Last post by  Bugman
I’ve done the marine battery terminal mod, but I need to replace the cable that goes across the radiator, and connects the positive posts of both batteries. But I need to know the gauge/thickness of the cable so I buy the right one.
1 - 9 of 9 Posts
Measure it, and look it up on this chart: https://en.wikipedia.org/wiki/American_wire_gauge
  • Like
Reactions: 1
I used a 2/00, it's bigger but worked fine
  • Like
Reactions: 1
I also went bigger. The stock cable is bare minimum for the DC flow.
The stock cable is plenty for any conceivable draw with the factory or direct-replacement batteries, starter, alternator, & other loads.
That's a funny joke
  • Like
Reactions: 1
It's a 4 gauge on my '04 and that is definitely way too small IMO. I ran a 2/0 when doing my replacement. Of course I also replaced all of the factory battery leads with bigger/better.
  • Like
Reactions: 1
Factory gets by with the bare minimum, the bean counters won't let them even if it is the consumer that pays in the end.
When I replaced all of my cables I went larger, less wear and strain on them than using the factory gauge especially if you add any aftermarket electrical.
  • Like
Reactions: 1
:rolleyes::rolleyes:
:rolleyes:
1 - 9 of 9 Posts
