1 - 20 of 55 Posts
· AllYourBaseAreBelongToUs
I've got the old SX system from DI on mine right now. Had it for about 2 years now. PUmp went out once about 6 months ago, emergency replaced it with another SX David had laying around that was about 3 years old. It ended its commission about 3 months ago. I've got a new one onthere now and haven't had any issues.
I'm gonna switch to the DI FASS system as soon as $$$ allows though.
· Registered
FASS 150/180:D
· Registered
Is that the one where he actually installs the correct springs in it so it will flow enough to hit 50 psi?
· Don't EFN worry about it
I have a single super duty with a 10 micron racore. I will have to add another s/d pump here real soon. Mods are a commin. :D
· Registered
What do you mean by the wrong spring, I also have a 150/180 to install
· Drink til she's cute
Same here, got the old sx set-up with the sump in the tank. No issues for 3 years. Seems to get the fuel from point a to point b
· Registered
My first pump went out, David sent me another one but only goes to 62 max. The old pump went to 70.:cool:
· Registered
Or maybe it is one of the new ones that has a pump you can't hear over a block away over the noise from the engine.
· Registered
My FASS 150/180 holds low 60's.. It's also very loud!!
Dennis has a new fuel system coming out that should be awesome. Send him an email for details.
· Registered
ok so i know im loosing pressure in the extrme setting, and i have no fuel pressure gauge, but how bad do yall think it really is? i can deffinately feel the lack of power up top. do i need to add a second pump or a whole new system?
· Registered
You are probably loosing about 5-7 psi of fuel pressure. But your lack of power up top in the extreme settings may be due HPOP? Do you have a big oil set up? If you dont that may be the case. I installed a HPO guage about a month ago and I was surprised that I can drop it at WOT in my 140 setting.
· HP Junky
With my stock fuel system and stock ad injectors, my pressure would drop clear down to around 25psi. You'd be amazed hom much the pressure could drop.
I know I was suprised when I put my pressure gauge in, I'd never thought that stock injectors would tax the stock system that bad.
1 - 20 of 55 Posts
