41 - 45 of 45 Posts
6.0 Guru
So the zerex g05 is okay to use or no?
It is not ELC. Don't use it. That is what Napa tried to sell me first. Same stuff as Ford Gold.
The 6.0 is known to blow head gaskets. This is why it happens. The Ford Gold coolant contains silicates. The silicates are not able to handle high EGT's generated by a good load or relatively high boost when run through the EGR cooler. They break down into a jell like sludge and fall out of suspension. This crud gets caught up in the tiny coolant passageways of the oil cooler. As the cooler clogs up it restricts coolant flow to the egr cooler. Now the egr cooler doesn't have enough coolant to carry off the heat generated by high EGT's. The limited amount of coolant in the egr cooler flash boils causing high pressure in the cooling system and the truck pukes coolant from the degas bottle due to the pressure. (it has to go somewhere)
Your uninformed Powerstroke owner is not monitoring his coolant temps and oil temps so he doesn't know whats going on and he keeps driving it this way. The problem get worse, the pressure causes the egr cooler to rupture. Now the egr cooler is leaking coolant into the intake manifold which then runs into the cylinders. Again the high combustion temps cause the coolant to vaporize. This causes unacceptably high cylinder pressure, the TTY head bolts stretch due to the additional pressure and there go your head gaskets.
Ok now you know the problem. Here's the cure. Get a good engine monitoring solution like the Edge Insight so that you can monitor your ECT and EOT. If those temps get more than 15* apart at normal cruising when at normal operating temperature your oil cooler is clogging up. Rebuild it now to prevent all that down stream damage from occurring. Flush that Ford Gold coolant cxxp out of your engine with a couple bottles of Restore. This is made specifically to clean out that silicate residue. Now refill it with a silicate free Cat EC-1 rated ELC coolant. This removes the silicates that clog the oil cooler from the equation. If you live in an area where you don't have smog inspections delete the egr system. If you can't delete it replace the egr cooler with the cooler manufactured by Bulletproof Diesel. This is vastly superior to the Ford oem egr cooler and it will not fail on you. If you find that you need to replace head gaskets replace the TTY head bolts with ARP studs and use black onyx (Victor Reinz) head gaskets. If you have to replace the egr cooler always replace the oil cooler. That is the source of the problem.
Here is the fix
ELC is the coolant recommended and used by International for this engine. .
Coolant Flush for changing to ELC
Drain coolant by removing lower radiator hose. Drain block from plug on drivers side of the block. Remove the thermostat. Replace plug in block and put lower hose back on. Put thermostat housing back on without thermostat. Fill with distilled water. run for 5 minutes then drain as above..Fill and run 5 more minutes drain. Put in 3/4 to 1 gallon of Restore an top with distilled water. Drive it for an 60-90 minutes then drain. Flush 2 times with distilled water or whatever it takes to come clear. Put 2 qts of VC-9 or 3/4 to 1 gallon of Restore+ cost less and fill with distilled water. Drive it for about 60-90 minutes. Drain and flush after. Flush 3 more times with distilled water untill it come out clean. Replace thermostat or put in a new one. Put hose back, make sure block plug is tight. Add 3.5 gallons of ELC concentrate and top off with distilled water. Make sure to run engine for 5 minutes between flushes to circulate the water good. Have heater on set to hi while doing this to flush the heater core too. new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
If you like pictures have a look here.
Replaced oil cooler still difference in temps - Page 21 - Ford Powerstroke Diesel Forum
2 stroker
That's the most fukin informative and accurate response I've ever read. Nailed it.
41 - 45 of 45 Posts
