1 - 3 of 3 Posts
I am installing a lift and tires this week what air psi should I run? 35/12.5/18 Toyo M/T on stock 18x8 rims. They are E rated and I think 65 psi rated. I want them to last a while 1400 for 4 tires is steep;)
I'd most likely start at 55 psi front and 45-50 psi rear if you drive unloaded.
Then adjust them down from there if need be.
I run a 33/13 on my stock 18s and just run 60 psi, but that's because I often tow and haul weight. 55 front and 45-50 rear seem to ride well when I took a trip down to visit my sister.
1 - 3 of 3 Posts
