1 - 6 of 6 Posts
6.4 Rookie
So I decided to pull a few leafs out of the front of the 6in sky jacker lift on the '94 CC LB, and bought a 2in block to replace the 4in. Now the truck is all over the road. I am aware that some of the 6in comes with a trac bar drop bracket, but dont the 6 and 4in lifts have different drop lengths? How do I know what a stock length trac bar bracket measures to tell what size one I need? I'm assuming this could be the culprit for the bad road characteristics? Any thoughts? Then truck now sits at 2in lower than the 6in front and rear. So I consider it a 4in lift.
STILL LEARNING
Caster plays a big part in tracking. Also, did you play with your steering linkage at all?
ate lug
I went from 6" Skyjackers to stock w/ 3" RSK and reused my tracbar drop bracket w/ no ill effects. i did have to adjust my draglink to re-center the steering wheel though.
Are you sure your caster didnt change when you pulled those leafs out? Incorrect caster, or excessive toe-out (tierod) will cause vehicles to wander all over the road.
make ur track bar the same angle as ur drag link
6.4 Rookie
Thanks for the replies guys this week has been a mess I am going to tear into it this weekend to see if I cant fix these issues.
1 - 6 of 6 Posts
