1 - 12 of 12 Posts
Ok The wife already told me she is gwetting me a fuel pressure gauge. Im getting an autometer gauge with electric sender. Is there anything else I will need?
Also she said i had some other things i could get with my christmas money. Im thinking of getting a coolant filter setup. link to coolant filter setup
Im also thinking of getting a bypass oil filter setup but cant find one thats a direct bolt on setup. Not sure if there is one or not????
Thats about it. And yes I know there is probably already info on all of this all over the net but......... help a brother out.
Thanks
Josh
Discussion Starter #2
dang wish i could talk the wife into the stage 3 combo setup.
you'll need the adapter fitting for the electric sender
Oh and im wondering if this is a good idea or not also? ats coolant recirulation setup?
Thanks,
Josh
You can only put those on when the heads are off.
I did the ones from Elite when I did the studs and gaskets. I though it was a good idea and seeing that my truck weighs in at 12,000 lbs every day and then also tows a 10,000 trailer it needs all the help it can get.
going to order the gauge and adapter this week. Also thinking of getting the 6.4l banjo bolts too. Then hoping the wife will get me the stage 3 oil/coolant filter setuo for christmas. (she said maby.....)
Glad to see that I could be a bad influence ;)
Ah yes well I'm glad. Not sure the wife is but she knows I don't cheap out on truck parts so it was probably expected. Lol
looking into their ccv setup and fuel lines too...... But their fuel line setup while nice is a heck of a lot more then a couple 6.4l banjo bolts.
1 - 12 of 12 Posts
