1 - 20 of 23 Posts
· dinnerbooter treasurer
Hi guys I am going to be doing some welding on my truck in the next couple of weeks and I was wondering if I needed to disconnect anythng so I dont fry it, possibly PCM. Just asking.
· Registered
Just make sure you ground it correctly.
It couldn't hurt to disconnect the PCM though..
· <<< THE GAUGE WHORE...
I never have with exhaust systems and such...
· All Talk, No Walk?
I've never unhooked anything, and never had a problem. Maybe we should send this into Mythbusters so they can solve this dilemma once and for all...:D
· Registered
Just to be on the safe side, I would disconnect the battery. It only takes a few minnutes to do it and if it was me I'd feel a-lot safer.
· Banned
I didn't do anything but grab a fire extinguisher as far as safety when I welded the entire frame back together after sectioning ~15 inches for the shortbed :eek:
Still runs good :D
Couldn't hurt to unhook the batts though.
· Registered
As stated unhook the bat. I have welded on many of a rig and always un hooked the bat. if it has a comp. in it. Why take the chance? For the time it takes well worth it.
· Registered
You should unhook the batteries. The ecm doens't like power spikes. You also should weld on the frame as it's heat treated if you can avoid it.
· Banned
Now that I think about it, that truck has a battery disconnect switch in the front grille that was in the "OFF" position.
So then yes, my batts were actually disconnected.
Discussion Starter · #16 ·
I am going to start building my pipe bumper so I wont be welding on the frame. I had the bumper off today doing some mock up. I will get some pictures up when I get something accomplished.
· Braaaaaaaaaaaap
2000 F350
I have welded on my rockcrawler probably hundreds of times without ever undoing batts or worrying about the computer. Still runs great... rolls over alot...hmmm maybe that's the problem :brightidea: :flipa:
· Registered
1 - 20 of 23 Posts
