1 - 1 of 1 Posts
so my buddys 95 powerstroke is having a weird issue. It is a 5 speed and when he takes off it will want to stall, like the motor cuts out. It will do this in 1st and 2nd but not third. It only happens if he takes off above 1000 rpm, if he lets off the clutch in 1st with no throttle its fine then he can jam gears but if he tries to take off with throttle it will die out. It will not do this in reverse at all. We have changed idm ecm checked wires pedals and pretty much everything else. Any input on this would be greatly appreciated and needed. If you need any other info about it just ask im sure i missed a lot, thanks.
1 - 1 of 1 Posts
