Status
Not open for further replies.
1 - 4 of 4 Posts
Will
My scan gauge reads F water temp at -40 degrees at all times. Is this just a scan gauge thing or is something else at fault? My truck runs noticeably better when ambient temps are low.
<<< THE GAUGE WHORE...
Scan gauge (or any scanner for that matter) can not read coolant temps on a auto truck... The PCM does not even look at it.
Like CSIPSD said, you can't read that with a scan gauge. If you want to know your approximate water temp, check your oil temp. Most of the time water temp is the exact same as oil temp.
Will
Thanks guys
1 - 4 of 4 Posts
Status
