1 - 4 of 4 Posts
My truck is leaking water, and i believe its comin from the waterpump cuz the leak runs down the back of the harmonic balancer and on to the ground. What my question is, is a water pump on a obs the same as a superduty, cause my buddy has a brand new one for cheap. Thanks for the help.
Super Hauler!
Might also check the t-stat, mine leaked around the back where you couldnt see and i pull the pump and put new one on with new seal and found it was the t-stat later.
where is the t stat located.
superduty water pump's i believe are different in the way the top hose comes out. if you have to get a new one look into getting one for a T444e in an international truck, they have a water filter built into them. do a little searching and you will find a thread on it.
1 - 4 of 4 Posts
