There not too bad. KT Performancei've been debating this but the kits are a lil on the pricey side
can you feel a power difference? or were you just looking to cool off the egt's? i could def use it too cool egt's while towing but if im guna spend 400$ i want somthin that will aid in mpg's, power, coolingThere not too bad. KT Performance
KT Performance
Kenny has some of the best prices out there. I purchased the simplest kit and a 7 gallon tank. Was just under $400. Alot of money, but water is free.... So it wont cost me anymore money no matter how much I use it.
Power difference... No. Doesn't really register on my SOTP meter. LOLcan you feel a power difference? or were you just looking to cool off the egt's? i could def use it too cool egt's while towing but if im guna spend 400$ i want somthin that will aid in mpg's, power, cooling
i sure do ask for alot outa one product LOL
ive never pushed my egt's much past 1250* i like to keep her kool, i may go ahead n go thru with it and order one, thinkin ill probly run 70% water 30% meth, see how that treats it, how hard is the install and setup?Power difference... No. Doesn't really register on my SOTP meter. LOL
I wanted it for cooling EGT's so I could use my power longer if that makes any sense. I was having to lift off the pedal when the pyro hit 1400. Now, no lifting. I stay in it as long as I want.
I haven't towed really heavy with it yet, but im sure it will do what I expect it to while pulling a heavy trailer.
It wont help out my MPG's cause I dont make enough boost at cruising speeds to turn it on, nor do I need it on while cruising.
Both Nozzles come on @ 12 psi and dont go off till the boost gets back under 12.
Kinda weird to watch the pyro go backwards sometimes when Im still on the throttle....
Sooo easy to install. And I fit the pump and tank in one end of my tool box. Ill take some pics next time I think about it.ive never pushed my egt's much past 1250* i like to keep her kool, i may go ahead n go thru with it and order one, thinkin ill probly run 70% water 30% meth, see how that treats it, how hard is the install and setup?
ya that's why was running a pretty skinny mix, theres a guy here in town that runs the 50/50 boost juice or w.e it is they call it, and he swears by the stuff, but i know betterSooo easy to install. And I fit the pump and tank in one end of my tool box. Ill take some pics next time I think about it.
Remember, Meth is timing that cant be controlled.
Tim (dalpilot) runs 155cc's (IIRC) on his 6oh with a stock turbo and water and still tows with it. He was having a hard time controlling EGT's while towing an empty trailer without water. Installed the water, now he swears he would never tow without it again.
