I'm ditchin' the wastegate, what do I do with the solenoid and the wire harness?? Can I just unplug it, tie off the pigtail, And ditch the solenoid? Will it set a de-fuel code??
Negative, we are talking about the wastegate solenoid.Are you guys talking about the EBPV and not the Turbo waste gate????
Just so you all know, the wastegate is actuated and operated by boost pressure. It does not, however, relieve or in any way dump boost pressure. The wastegate bypasses excess drive pressure (read as exhaust gasses) around the turbine wheel to slow the turbo down and thus reduce or maintain a steady boost pressure.The actuator moves the rod and opens the wastegate and relieves excess boost pressure into the turbine housing of the turbo and out the exhaust.
