1 - 15 of 15 Posts
obs addiction
Hey guys, just installed a denso high torque starter, heard some metal on metal after first start, so pulled the inspection cover and restarted, noticed the flex plate has a slight warp to it. Would this be why I get alittle starter rub? Seems like it disengages slow only in a certain spot, it does it once every 5 starts. Should I shim the starter or replace the flex plate?
I have a flex plate that I am not using. It came with a used engine I purchased. I am running a zf-5. I will take $35 plus the ride, if you need one.
obs addiction
I'll keep ya mind on that, I wanna look into some billet ones first. So far they are expensive!!
obs addiction
Anybody else have the starter hit the flex plate when everything's cold? Wondering if I possibly got the wrong one.... Only hits when cold and and makes a winding up sound if I use reverse when cold. If it runs for 15 minutes everything is fine.
My standard start on the 96 will do that it will bounce off and grind. It only does this every so often. I need to replace mine.
obs addiction
Wonder if shimming will help for a temp fix for now.... Not the right thing to do but I currently don't have another truck to use right now.
obs addiction
Would the flex plate also explain the recent vibration that started a week ago? 25+ I get a vibration with foot on the skinny pedal! take it off and it's gone. Thought my u joints were going so I did them all and a trans mount while I was there. Vibrations still there. Don't say tires cuz I balanced them and had them off with truck on hoist. Still did it.
IT could be cracked
obs addiction
Discussion Starter #9
Yeah I was afraid it might be, pulled the trans today to just be sure since snows on the way again and can't afford to have this truck down too. No cracks, so I did a rear main and put it back together. I'm stumped
obs addiction
I ended up shimming the starter out with a washer on each bolt. Stopped the grinding and starter still engages fully on the flexplate.
STILL LEARNING
You pulled the trans and did not replace the flex plate even though it was questionable?
Did you remove the flexplate and look at it. Most of the time they crack behind the retaining ring and you can't see it w/o removing the flexplate. Then its pretty obvious where the problem is.
obs addiction
Yeah I know it wasn't the best thing to do, this is my plow truck now and I just wanted to be sure that I wasn't gonna have a major break down while I was out plowing the other day. I ordered a new flex plate just waitng on it still. It was cheaper for me to check out my current flex plate then have to pay someone to plow for me..... I don't wanna have to pay 1200 bucks out if I don't have too ..... If u know what I mean
obs addiction
Discussion Starter #14
Yeah I pulled it and inspected it. How else would I have been able to do the rear main? :poke:
LOL
Sorry missed that part completely. Most people don't check so that's why I mentioned it. I got burned once the same way...
1 - 15 of 15 Posts
