1 - 8 of 8 Posts
how much trouble to swap front and rear axles from a 05 to my 00. i have a 8" lift on mine now with 4.56 gears. i want to do it to get better turning radius. what do you guys think i should do.
The 05 axles are wider, also they are set up for coil springs instead of leaf springs. I'm sure somebody has done it and will provide more info.
Its a easy swap, if I can do it to a OBS a SD is a piece of cake. If you still want the lift then don't get the stock radius arms from the donner..just get a kit with the 4 link arms.
How much better is the turning radius on the newer trucks vs the older? That just seems like an awful lot of work just to get a little better turning radius...
It wasn't me
Its a lot better plus 05+ has bigger brakes and 35 spline inner and outer axle shafts
Diesel Huffer
dont you also have to swap the steering box out? thought I read that some where
1 - 8 of 8 Posts
