1 - 6 of 6 Posts
Does anyone have a write-up on removing the passenger side valve cover? Or does anyone have pointers for removal. I just want to make sure I don't run into any surprises when checking my fuel pressure sensor. Thank You
Remove air intake. Remove oil fill tower. Remove bracket near rear of cover. Take the heater return hose off the return pipe. Be careful of the return pipe, it is plastic and very easy to damage.
Thank you
<-•DEISEL CRAFT•
you half to disconect batteries neg post both
remove air box
remove turbo air inlet and oil fill at same time its 4 8mm and 2 clamps
remove far right pcm hasrness connecter
and the black one that is behind the airbox
remove heater hose BEWARE that plastic will break if you break it you half to pull the intake
pulll the glow plug control module
theres like 3 or 4 conecters near the module you will have to disconect
pull the glow plug conectors out of the valve cover
unscrew the valve cover bolts
they will most likely stay in the valve cover
thats how you remove passanger valve cover
thank you for the replies. Got it off and FPR sensor changed and she runs like new and no more codes
1 - 6 of 6 Posts
