1 - 11 of 11 Posts
Dads late 99 he found his pump was running so he bought a new one and its doing the same thing. anyone know anything about this thing?
Pry would be a Jose leaking at or on the way to one of the hubs if it's four wheel drive.
If it is running all the time and if a 4X4 the hose to the hubs would not have anything to do with it as there is no vacuum there untill the switch on the dash is turned to 4X4. There is a vacuum leak some where, check the hoses from the pump to under the dash.
I also have the same issue with my 2000 F350. I have narrowed it down to the vacuum reservoir, but I am having issues locating a new one. Any suggestions?
All done now
Find the leak. Torch a cheapo butterknife and weld the plastic back together. Play with the torch and the knife on some other plastic first to get the hang of it.
dinnerbooter treasurer
I think someone may have told him that in chat the other day. :poke:
Sounds good, thanks for the tip! I'll let you know how it turns out :D
I think I would epoxy or fiberglass the leak if I found it.
Please post you findings with your possible leak in your vacuum reservoir.
I'm thinking that is were my leak may be coming from.
I am planning on tearing into it on Saturday after I get off work. I will let you know how it turns out.
1 - 11 of 11 Posts
