1 - 4 of 4 Posts
Right now i have the suncoast superduty rebuild kit in my truck with the billet input shaft. I'm using just regular mercon/dextron trans fluid cause that's what suncoast recommended at the time. Today i just had a buddy of mine order a suncoast triple disc converter with a 2000 stall and he will also be installing it. Now, how much trans fluid will still be in the trans after he drains it? Only reason i'm asking is because i want to switch to the new mercon LV fluid. Just wondering if it's gonna be bad if i was to mix a bunch of LV fluid with a couple quarts of the mercon/dextron stuff.
The Unseen Mod
Id just go ahead and flush it put new fuild in her. Better to be safe.
well this is something i'd hafta do at the dealership then. I'll just have him fill it back up with the mercon/dexron stuff then have my other buddy who works at ford, do a trans flush on it. I'm assuming that would get all the mercon/dexron stuff out and get new LV or SP in it.
1 - 4 of 4 Posts
