1 - 20 of 29 Posts
Does anyone know how much Ford charges for the upfitter switch block by itself and how hard it is to wire in?
Mine came with the coin-holder and I'd rather have the switches, haha
Thanks!
--Cameron
That's what I would think, too.
It$ only money
Very nice, thanks!
Still learning
Is that just for the '08 and newer trucks or is there wiring on the '03-'07 too?
On the 2007 and earlier there is a block that you have to by that has I think 4 fuses in it that mounts behind the glovebox. Look on Ebay there is a guy on that sells them for $150 everything is included and the are OEM I believe. Here is the Ebay Item number 160396258172. Maybe you can email this guy about 2008 switches.
It$ only money
fordupfitter is who i buy from on ebay. hes a for ddealer so he sets you up direct. has them fr all years. nice guy!!
Jim D's '19 F-450 Dually
15 Minutes? You're a better man than I...
...or your Daughter is one hell of a mechanic! :hehe:
I had everything figured out quickly except for that plug in your photo number 2! I spent two hours out there and could not find that damned plug. :bang
Thank you sincerely for that photo - I'm pretty sure that will do the trick. I'll look again on Monday when I have some time. Nice write up... thanks again!
And to "CamTom" and "BFT", the wiring is not there! You have to buy the kit - switches, relay box and sub-harness. As "Norris" said, "Fordupfitter" on eBay - that's where I got my kit too!
Good to know, thanks!
It$ only money
i wasnt lucky enough to get the switches so i did them myself. was VERY EASY, took me and my daughter about 15 minutes.
I started by buying the kit from ebay from fordupfitter, cost was about 140 bucks.
http://motors.shop.ebay.com/fordupfitter/m.html?_nkw=&_armrs=1&_from=&_ipg=
hes got instructions with the kit, heres picks to go along.
start by popping off the silver trim piece thats got your vent and lights in it. you need to pop the bottom loose, them the rest will follow.
you will have a bracket that sticks out without anything mounted and lots of space around it. That is where the fuse box will bolt in.
once the fuses are in you need to pop the panel off under the wheel. start by poping the bottom loose then slide it up and the rest will follow. if you look straight up into the dash from the floor board by the gas pedal, you will see a grey connector and wire harness and theres nothing but a dead plug on it. that is where the grey connector from the new fuse box connects and gets you power.
once that is in you need to ground the other wire.
then youve got one small wire harness that goes to the switches, similar to a phone jack. you must send it up to the coin/brake controller area. its very tight, i used a piece of wire to fish it up thru the cluster. i poped the little black trey above the gas pedal out to help fish the wire. once u pop the coin tray out(real PITA) you can plug the switches in and pop them in.
now youve got switches. theres a nice little sticker on the wire harness that says what wire goes to each switch. without anything hooked to them they still light up when flipped.
hope this helps guys!!
Josh
This image has been resized. Click this bar to view the full image. The original image is sized 604x453 and weights 55KB.
UA local 761
Whats the purpose for the Upfitter Switches? I have them on mine but not sure what they're for. I remember reading that someone had wired a high idle to one of them... How can I do that? :confused:
Discussion Starter #20
Dang it, beat me to it!
1 - 20 of 29 Posts
