1 - 6 of 6 Posts
Hello, I’m getting ready to delete my egr cooler. I know there are tons of options But I’m leaning toward welding my current cooler at both ends and removing the scoop from the up pipe while I’m in there. Is the scoop something that is removable or is it best to just buy a quality pipe without the egr flange? If so who sells a decent one? Thanks in advance, Brandon.
There's a block off for it. Little round disc.
Do "6.0 powerstroke up pipe block off." Thatll round up some results.
Trust me, I got this...
If you want a pipe, IPR Research makes the highest quality pipe and egr delete hands down. Priced accordingly though. Why just weld it up since you're there? Delete it and make your valley look a bit better.
Administrator
you can get a 03 OEM up pipe with no scoop or if the bellows are good on yours you can cut the existing one out
if you don't need the egr cooler in place for inspections then by all means use a method that deletes it and get a non y up pipe
1 - 6 of 6 Posts
