1 - 6 of 6 Posts
Hey guys is there any way I can buy and mount the up fitter switches and factory brake controler into my 2003 f350
King ranch?
No easy task on the brake controller. It has a pressure transducer mounted on the mastercylinder, and is integrated into the ecm. Anything is possible....
How would it be to at least do upfitter switches?
09 6.4
up fitters wouldnt be bad. you'll need to switches themselves and the wiring harness that connects the switches to the main body harness.
find the connector on the main body, route the wiring, plug in to switches. that simple
Administrator
go on ebay and get the whole up fitter kit breaker box( behind glove box ) switches ,coin holder 1/4 filler
it the brake controller is doable but you need a new master cyl and programming
might not be worth it
1 - 6 of 6 Posts
