1 - 6 of 6 Posts
2003 6.0, had no power or boost at low rpm, above 2500rpm at WOT
it would build boost and make power. Unplugged EBP and truck runs like a beast. Will it hurt to run it unplugged for a day or so .
No, it wont hurt anything. I ran mine like that for a little while as I was trouble shooting an EBP problem. More than likely, your tube is just clogged with soot. Clean it out and you should be good to go.
Thanks for the info!
Keep something in mind though. when I had an EBP problem, I had issues that where opposite of what your experiencing. My low power was fine, I just had a hesitation on higher RPM's and pulling up a grade.
What other problems did you have when I unplug mine it still reads 6.5
"resident smarty pants"
Wheehop hasn't been seen for 3 years
Sounds like a bad EBP sensor. Can you post the units for that reading (I mean psia, psig, kpa, in H20, in Hg, etc)
1 - 6 of 6 Posts
