1 - 20 of 33 Posts
owner/president
Have any of you all done anything different for extra lighting? Maybe two lights or LED's?
OEM Moderator
I have two of the OBS factory lights under the hood on mine. One on each side.
:popcorn:
wanting to do the same thing?
owner/president
owner/president
Thats what i was thinkin also. Thanx for the input.
owner/president
bump....
owner/president
Discussion Starter #9
FNG
owner/president
owner/president
owner/president
Discussion Starter #14
Did you buy yours new from a dealer or some place else or from some one?
<<< THE GAUGE WHORE...
I had planned on adding two cheap fog type lights, but have not gotten around to it. Problem is they will run your battery down rather quick.
You can just put a switch somewhere in the engine bay to turn it on when necessary.
That is the exact setup I am running
ive thougth about this a few times also.i wana do a couple leds and have then hooked to a switch under the dash. ill probably do the ligths when i replace my under hood liner
Understand that, but even still... If you need the hood lights your more then likely broke down and will need the battery power to get running again... I like the LED light option, MUCH lower draw.
1 - 20 of 33 Posts
